My 3rd NX TPS switch just went south.
Old Sep 22, 2002 | 11:40 AM
Tuan Le's Avatar
Default My 3rd NX TPS switch just went south.
Is there some quality control problem with NX TPS switches?
It hasn't been 5 months and I have already gone through 3 different NX TPS switches. :mad :mad :mad The first two were within 5 weeks. And the 3rd one lasted for close to 4 months. Agggrrrrrrr. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> (And yes, all 3 of them were wired correctly as instructed by NX. I have double check a billiion times. And plus, it wouldn't have worked if it wasn't wired correctly).
I'm going send it back to NX and see what's going on. <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
<small>[ September 22, 2002, 11:43 AM: Message edited by: Tuan Le ]</small>
Old Sep 22, 2002 | 11:45 AM
ScottyG's Avatar
Default Re: My 3rd NX TPS switch just went south.
That ain't good. Where do you have it mounted?
Old Sep 22, 2002 | 11:51 AM
Tuan Le's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ScottyG:
<strong>That ain't good. Where do you have it mounted?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have it mounted in the passenger footwell. I thought about water condensation so I wrap the damn thing with several layers of electrical tape.
Here is the link over @ Corvetteforum, many others are also having problem with these damn TPS switches.
http://forums.corvetteforum.com/zerothread?id=393481
-Tuan
Old Sep 26, 2002 | 03:50 PM
00bluehawk#111's Avatar
go to radio shack and buy a momentary switch. i have it so the pedal hits it at wot and damn it works great w/no problems
Old Sep 26, 2002 | 08:39 PM
purevilss's Avatar
Well I just got a new NX MAF kit and I have been working on the TPS switch for two weeks now and can't even get a light. I have checked the wires a thousand times and god forbid I try and talk to NX. All I get from them is, "you must have something wired wrong." Like they can't take responsibility for their parts. Is it too much to ask for everything in a kit to work?
Scott C.
Las Vegas
Old Sep 27, 2002 | 02:17 AM
Tuan Le's Avatar
Well....at least now you all know it wasn't just only me. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Sep 27, 2002 | 03:10 PM
Scalpel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 00bluehawk#111:
<strong>go to radio shack and buy a momentary switch. i have it so the pedal hits it at wot and damn it works great w/no problems</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What's a part # on one of these momentary switches at Radio Shack, I can't find any there.
Old Sep 30, 2002 | 10:48 PM
SloViper's Avatar
Did you have the same person install each time? We have done over 30 TPS switches and have only had one give us trouble.
Old Sep 30, 2002 | 11:42 PM
Tuan Le's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SloViper:
<strong>Did you have the same person install each time? We have done over 30 TPS switches and have only had one give us trouble.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I did it myself. As I have mentioned before, it was working great for couple months so I know for sure all wires are connected correctly.
Black wire goes to ground, red goes to +12V, white goes to RPM signal from PCM, and pink goes to relay.
Old Oct 1, 2002 | 10:39 AM
purevilss's Avatar
The white don't go to the RPM signal, it goes to the TPS signal at the throttle body or ECM.
Old Oct 1, 2002 | 10:44 AM
Tuan Le's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by purevilss:
<strong>The white don't go to the RPM signal, it goes to the TPS signal at the throttle body or ECM.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry, that is what I meant. I got mixed up my MSD RPM Windows Switch in the previous post. I do/did have the white wire going to the TPS signal on the throttle body.
Cheers.
