Need advice on a 200 shot?
Old Apr 11, 2013 | 05:43 AM
lilmiller74's Avatar
Default Need advice on a 200 shot?
Like the title says I am thinking about running a 200 shot. I have an 05 vette stock bottom end with 92k miles..I have ran a 150 shot all last year with no issues pulling off the rail. This year I am in the process of completely re-doing my nitrous kit, actually just finished.
My set up now is a stand-alone and ill be running shell URT race gas in it, with a low psi pump, NOS super power shot noids (I think), a HSW 90 mm plate, and Br7ef plugs. Do you guys think I should just stick with running the 150 with this set up or should i be ok to jump up to a 200 shot?
Let me know what you guys think, any advice is appreciated.
Old Apr 11, 2013 | 09:42 AM
Killer5.3's Avatar
If you aren't sure what solenoids you have, I would figure that out first before you do anything else. You need to make sure of what you have, that they are in good working order and will flow the proper amount of nitrous so that you can get you a/f ratio dialed in properly.
Old Apr 11, 2013 | 03:25 PM
I know what noids they are I just cant remember off the top of my head, and I know they are in good working order....
