TR 230/224-111 LSA
Old Sep 26, 2002 | 04:42 PM
Nickn20's Avatar
Default TR 230/224-111 LSA
how do you guys think this cam will do with nitrous? I know according to older engines its not optimal, usually a split pattern cam would be better. but we will see <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 27, 2002 | 07:33 AM
Bad02WS6's Avatar
Default Re: TR 230/224-111 LSA
I'm no expert. But with nitrous I beleive it's better to go bigger on the exhaust side. 224/227
230/224 is for N/A motors, but nitrous will still work sweet!
Old Sep 27, 2002 | 07:46 AM
Z00's Avatar
Z00
Thunder Racing was saying it would cause a lot of cylinder pressure if you sprayed while using this. Might want to talk to them about it.
I have a friend with this cam that was going to spray but after he talked to them he decided not to.
Old Sep 27, 2002 | 11:09 AM
Patrick G's Avatar
LS1 Tech Administrator
I have this cam and it's fine on the spray. Unless you're running a 200 shot or bigger, buy a cam that makes you the most power N/A, then spray on top of it!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 27, 2002 | 01:57 PM
Nickn20's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Patrick G:
<strong>I have this cam and it's fine on the spray. Unless you're running a 200 shot or bigger, buy a cam that makes you the most power N/A, then spray on top of it!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats exactly why I went with this cam! NA performer, but still ok with a mild shot of nitrous! I know with its cam specs it would create a lot of cylinder pressure, maybe a shitload of TQ too, I'll make sure I have a really free flowing exhaust, probably electric dual cutouts on a 3 inch y-pipe.
Old Sep 29, 2002 | 12:38 AM
Z00's Avatar
Z00
Patrick, do you have any fuel upgrades for your car?
Old Oct 1, 2002 | 03:58 PM
Ian's Avatar
Ian
How safe is this cam w/a 150 wet shot? (stock bottom) -- what fuel upgrades are recommended?
Old Oct 1, 2002 | 04:01 PM
NicD's Avatar
7 Second Club
That thunder cam with nitrous is going to create a lot of cylinder pressure. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Oct 1, 2002 | 04:45 PM
Nickn20's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nic00Z28M6:
<strong>That thunder cam with nitrous is going to create a lot of cylinder pressure. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">the 111 LSA should help bleed off some pressure. maybe I should set a spray on point to about 3400 rpm instead of 3k?
Old Oct 2, 2002 | 12:43 AM
bigSS's Avatar
<strong>I have this cam and it's fine on the spray. Unless you're running a 200 shot or bigger, buy a cam that makes you the most power N/A, then spray on top of it!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My question is how much horsepower and torque are you sacrificing ON THE SPRAY? Sure, if may work fine, but how much could you gain if you went to say a 224/230???
Old Oct 2, 2002 | 03:55 PM
Patrick G's Avatar
I'm actually making more rwhp and tq on the spray with my TR 230/224 111LSA cam than I was with my TR 224/224 112LSA cam. No big surprise. Remember, I still have 224 degrees of exhaust duration. The 111LSA keeps the intake valve from closing too late which helps on the spray. I'm running stock '98 fuel pump. That's why I'm limiting my shots to a .062 jet (125 shot). Anything bigger is approaching the limits of the fuel delivery capacity (and the stock shortblock capacity, LOL).
Honestly, a 125 shot is pretty small and does not require a specially made cam in my opinion. I'd rather be fast N/A and have the nitrous on hand for the really fast guys. BTW, with all the 422s, Vipers and Supras running around, keeping the bottle open is a necessity in Houston.
If you're going to run a 200 shot or bigger, then it's time to start rethinking cams. Under that, just pick the cam that works best N/A and spray the **** out of it (with the proper tuning of course).
__________________
Old Oct 2, 2002 | 06:42 PM
SSprayn's Avatar
That cam should work but 114 LSA is recomended for N20 use. I am waiting for the install on my TR 224/227 cam. Then we'll see how much hp my car is worth.
Old Oct 3, 2002 | 05:23 AM
SSDriver's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSprayn:
<strong>That cam should work but 114 LSA is recomended for N20 use. I am waiting for the install on my TR 224/227 cam. Then we'll see how much hp my car is worth.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You must post those numbers when you get them, cause I'm thinking of getting the same set up.
