4.8L e85+150 wet shot...Questions
Getting near to the end of my engine swap in my 91 supra
I was going to do a turbo setup(bought everything) but decided i would play with nitrous for this year.
Mods:
Walbro 400 fuel pump
42lbs injectors
Aftermarket fuel rails
Aeromotive A1000 1:1 raising rate
LS1 intake
Truck style CAI
Hooker CTS-V manifolds(for fitment reasons)
LS6 yellow springs
Stock cam/bottom end(top piston rings gapped)
Stock trans/convertor
Nitrous setup:
Main 10lbs bottle, solenoids(n20, fuel and purge)
WOT switch
RPM window switch
Nitrous plate
Fuel switch(picking up this weekend)
With the above info. How well will the motor hold up to 150hp shot?
In order to run nitrous at the drag strip I need a blow down tube. Can i install this will a full bottle of nitrous? Im thinking not.
What plugs would be good for this setup?
Thanks
P.S...This is my 1st playing with nitrous. Learning(reading) as I go.
Mods:
42lbs injectors
LS1 intake
Truck style CAI
LS6 yellow springs
Nitrous setup:
WOT switch
RPM window switch
Nitrous plate
Thanks
Thanks for the info
Timing will be pulled once i get the swap finished and tuning will begin
As of right now my tuner has downloaded my pcm with a 5.3L + E85 base tune with 42lbs injectors.
