Another Launching M6 Question
Old Apr 17, 2013 | 12:39 PM
Canada204's Avatar
Default Another Launching M6 Question
Is it bad to launch with spray in first gear? Ive launched in First gear with the nitrous outlet window switch not locking out any gears. Ive found that it cuts my times down by alot. Ive been launching in first gear at about 3500 rpms and feather it for a wee bit then go wot traction isnt a issue. Any thoughts welcome just want to make sure im not going to hurt anything.
100 shot M6 Bias MT
Old Apr 17, 2013 | 02:11 PM
brandon@nitrousoutlet's Avatar
As long as everything in your drive train is built to handle it you should be fine. If you're throwing that much horsepower at a stock car the weakest link will show its face. If you have a 10 bolt in the car its only a matter of time...
Old Apr 17, 2013 | 02:29 PM
HCI2000SS's Avatar
Well it sounds like you definitely have some sticky tires, and if you are on the stock rear i'd stop that s**t right now lol
Old Apr 18, 2013 | 01:16 AM
Canada204's Avatar
Moser 12 Bolt PST Drive shaft Some tranny work c6 zo6 clutch that is the weak point.
Would it be a smart choice to use the progressive function on Nitrous outlet Window Switch?
If I were to go WOT accidently with the clutch pressed in will it spray?
