Fuel press switch
Thanks,
purevilss@aol.com
<small>[ October 11, 2002, 01:21 PM: Message edited by: rob-ss ]</small>
<strong>Under the little black rubber cover there is an Allen screw. Turn it out to raise the activation pressure and in to lower. You can set it on a bench with a calibrated gauge and air supply and multi meter.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe you have that backwards. The further you turn the screw in, the more fuel pressure is needed to trip the switch.
