what progressive, window switch ect....
Old Apr 19, 2013 | 10:25 AM
ISprayOnU's Avatar
Default what progressive, window switch ect....
I got the direct port kit installed but what do I need has in Nitrous Progressive Controller, timing, window switch ect....
Old Apr 19, 2013 | 10:27 AM
Nitro Dave's Nitrous Outlet's Avatar
What does your set up consist of? On the direct-port system how many solenoids are there and what is the amp draw?
What accessories do you currently have?
Dave
Old Apr 19, 2013 | 01:14 PM
ISprayOnU's Avatar
Its ur guys nitrous direct port kit on the fast 102. 2 fuel solenoids and 2 nitrous solenoids. I just want to know what other stuff I need has in progressive, switch, timing to run the 150 shot. Buying the stuff from u guys
Old Apr 19, 2013 | 03:12 PM
The NOS mini will control the system well. It will give you the window switch, TPS activation,time base progressive, trigger out put and control two stages.
http://nitrousoutlet.com/index.php/e...ontroller.html
The lingenfelter is a great timing controller. It will remove up to 15 degrees of timing. It has a 0-5 volt reference wire so that you can verify that it is removing timing. It also has a built in Two step.
Dave
Old Apr 19, 2013 | 03:59 PM
ISprayOnU's Avatar
All I need is both of those and thats it?
Old Apr 19, 2013 | 04:13 PM
brandon@nitrousoutlet's Avatar
In order to do progressive, pull timing and have a window switch yes that is what you'll need. Do you have everything else? Bottle?Heater?Plugs?FPSS?
