How to check if nitrous is flowing?
Old Oct 3, 2002 | 10:17 PM
BLUEBYU's Avatar
Default How to check if nitrous is flowing?
I am thinking I may have a blocked line on one side. I tried to check by turning on the arming switch and activated the WOT switch with the ignition on but not actually running. No go. What am I missing here to activate the solenoids?
Does the engine have to be running? If so, I am not used to opening it up standing still. Any help here? Thanks.
Old Oct 3, 2002 | 10:19 PM
BLUEBYU's Avatar
Default Re: How to check if nitrous is flowing?
BTW, purge is working.
Old Oct 4, 2002 | 07:49 AM
etperformance's Avatar
You have to put a jumper wire between the two leads on the fuel pressure safety switch as well.
Old Oct 4, 2002 | 08:19 AM
PewterZ's Avatar
If you're purgeing nitrous then you have flow all the way up to the nitrous noid.
Old Oct 4, 2002 | 02:12 PM
BLUEBYU's Avatar
The purge noid is upstream of the power noids. I think the blockage is there since it was fine before purge install. I just realized I can activate the WOT switch with the car running at idle...doh. I am going to give that a try.
Old Oct 4, 2002 | 05:00 PM
383LQ4SS's Avatar
Be careful. Best to pull the lines off and point away from the Maf or intake. It will surge if nitous is sprayed at idle.
