nitrous question
Old Apr 22, 2013 | 01:28 PM
ISprayOnU's Avatar
Default nitrous question
I just bought this nitrous nos kit but just needed the nitrous progressive out of it and nos bottle opener from a guy that was selling it.
It was a cold fusion wet kit, nos p.o.d nitrous controller, bottle heater, nitrous progressive controller. For $200 got a good deal
The question is do I really need a NOS P.O.D nitrous controller?
Can the Nos bottle opener work with nitrous outlet bottle?
Current setup is Nitrous Outlet direct port nitrous kit with Fast 102, dynotune nitrous gauge
Old Apr 22, 2013 | 01:59 PM
Nitro Dave's Nitrous Outlet's Avatar
That sounds like a good deal.
Which bottle opener is it? If its the one that goes in line get rid of it. They are junk. If its the one that replaces the turn know its a nice unit and it will work.
The P.O.D is not a bad unit. You could use it or sell it and make back your 200.00
What nitrous controller?
Old Apr 22, 2013 | 02:59 PM
ISprayOnU's Avatar
The opener has a nut on the bottom I guess where u can put it over the nozzle but not for sure just got it.
What does the P.O.D do?
The nitrous controller is NOS mini stage 2 Nitrous controller
Old Apr 22, 2013 | 03:07 PM
brandon@nitrousoutlet's Avatar
Considering the NOS mini is 254.99 I'd say you got a smokin deal!
Old Apr 23, 2013 | 09:09 PM
ISprayOnU's Avatar
I have the NOS Mini Stage 2 Nitrous Controller and FPSS. What else do I need?
Old Apr 24, 2013 | 09:17 AM
How are you pulling timing?
Old Apr 24, 2013 | 10:59 AM
ISprayOnU's Avatar
Dont have that yet. What else?
Old Apr 25, 2013 | 10:34 AM
LNC-2000 is good for pulling timing. What about plugs?
Old Apr 25, 2013 | 11:59 AM
ISprayOnU's Avatar
I need set of plugs
What about TPS Switch or Window Switch?
Old Apr 25, 2013 | 02:44 PM
The size shot you're planning on running will determine which plugs you'll want to go with. As far as TPS Window Switch I'd suggest the NOS Mini 2-stage Progressive controller. Feel free to call me and I can get you hooked up with all this stuff!
