nitrous power loss on dyno
Old Apr 24, 2013 | 05:26 PM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default Dip in graph - possible clutch slip
To see if the dip in the graph is clutch slip have them plot a graph showing engine RPM versus chassis dyno roll speed (MPH). If it is clutch or tire slip you will see a change in the slope of the line in that area.
Originally Posted by k_garretson23
looks like the clutch slipped, i have a similar dip in my graph.
Old Apr 24, 2013 | 05:30 PM
LS1Tech Sponsor
Default Knock
Does the calibration have the knock sensitivity changed? Could it be real knock that the ECM/PCM isn't noticing? A good way to check that is to put much higher octane fuel (aka knock unlimited fuel) and see if it changes. If you are on 93, try VP109. If it goes away then it was probably knock. If it doesn't then it is probably something else.
Originally Posted by boostinsidewayz
The tuner looked at the logs and said it pulled no timing. He's a reputable ls tuner, so I don't think he would have missed it after 3 pulls. I appreciate your help but I don't think that's it.
I just swapped solenoids and ran new wiring. Gonna go for a test drive soon.
And when he changed the timing for the nitrous, 4* being pulled while running all motor, it only dropped 10hp
Old Apr 24, 2013 | 07:17 PM
ShiznityZ28's Avatar
i just doubt its slip or random if its exactly 2.5 in every time and its not the same rpm.
Old Apr 24, 2013 | 10:53 PM
itsslow98's Avatar
Yea its weird that it would slip after peak torque and mid pull.
Old Apr 25, 2013 | 01:51 AM
boostinsidewayz's Avatar
Originally Posted by brandon@nitrousoutlet
Did he look at the voltage?
Originally Posted by Roger Blackmore
X2 on the voltage. Check it in the data log. I've seen voltage drop do some weird stuff.
i dont know if he looked at the voltage. he is on vacation so i wont know until next week sometime.
i'll try putting some high octane fuel in it.
i appreciate everyones help in getting this figured out, track rental is monday, and i really want to jet it up before then
i upgraded all the wiring to 12 gauge. and i swapped out both solenoids with ones that were still in the box from nx after getting rebuilt.
i can still feel the dip in power
Old Apr 25, 2013 | 05:04 AM
DSS's Avatar
DSS
are you using a nano system?
Old Apr 25, 2013 | 10:56 AM
i have the nano in the car, but i stopped using it because it was annoying to fill. nano wasnt used for any of the pulls
Old Apr 25, 2013 | 01:07 PM
DSS's Avatar
DSS
can you post pictures to which port u used for nano on the bottle valve
Old Apr 26, 2013 | 01:46 AM
this isnt my car, but this is the same bottle valve that i have.
