Help me read my plugs
so there is still more power I can gain huh?
Step smaller on fuel jet to maybe 24 you think?
If you are dead set on keeping the shot small then take fuel jet out cause its pig rich. 46N needs close to a 23-24 fuel jet on a single nozzle setup.
What does the car run A/F wise NA? Target 12.5-13.0 on the nitrous and use timing to control the heat from there. Don't need all that excess fuel. Some of my fastest nitrous passes have been @13.5 afr up close to redline.
110 gas for safety lolDyno on Monday so Ill let you know 1/4 and dyno #s, if it survives
I know this is a cheap budget car but nitrous is not something to cheap out on. Good components will save you money in the long run. Seems like people who are known for their knowledge are trying to help and you're not hearing it. Get the right jets, get a timing controller and you will be much happier. 1 bad mix of race gas can cost you. I've seen it a few times with guys using it as a crutch on a street car. There is a lot left in the setup from what I'm seeing based off the plugs.
Just so long as new guys that are searching for info know this is NOT the proper way to use nitrous and will get you in trouble fast if you aren't lucky. This is a spray and pray method.
I agree with you this isnt the "proper" method to do this and def not on the street. At the track where I would read plugs after each pass and keep an eye on it so to speak.... I'll take that risk.
I'll keep you guys updated! If it wont rain we are heading to the track.
N/A trapped 110-111 mph. What do you guys think et is too low for that trap speed?
