Lingenfelter LNC2000 Diodes
Old May 14, 2013 | 12:18 AM
KTK Z28's Avatar
Default Lingenfelter LNC2000 Diodes
Hello everyone, I am getting ready to install my nitrous outlet F-body specific plate kit. To retard the timing i'm going to use a Lingenfelter LNC2000 box that I bought second hand, unfortunately it didn't come with the diode kit that I need. I tried calling Lingenfelter today but couldn't get anyone on the phone. My question is what diodes do I need? Is there anything specific that I am looking for or can I pick up the diodes from radio shack or electronics store? Also, do I just need one diode per solenoid? Thank you everyone for the help.
Old May 14, 2013 | 04:06 AM
JDEP162's Avatar
i am no expert, but i did just buy the lnc2000, so i have it brand new in the plastic, with all instructions. it cam with a seperate package with three of these diodes. the instruction say to install one as a bridge between the wires of every solinoid you have, mine for example just the one for n20. if u have line lock one for that also, and so on. if u need i have the diagram that came with it, if u cant find it online pm me. or ask in here.
Old May 14, 2013 | 07:11 AM
HCI2000SS's Avatar
Mine came with the diodes as well with the LNC-2000. Not sure if that's something you can just buy anywhere kind of thing. I'd try calling Lingenfelter again. I've never had problems getting a hold of them
Old May 14, 2013 | 08:21 AM
Somebody09's Avatar
i know Lingenfelter lists just the diodes on their site:
http://www.lingenfelter.com/mm5/merc...w=&range_high=
i would just buy one, unwrap it, test the resistance and all that good stuff, then buy another 20 from Jameco Electronics where they start at just $0.009 each
Old May 14, 2013 | 01:24 PM
Gary Z's Avatar
The diode's important parameters are maximum voltage and current, not resistance. You should follow Lingenfelter's recommendations and installation instructions.
Old May 14, 2013 | 09:49 PM
stroked383HSR's Avatar
hmm? I didnt get any diodes or instructions with my NEW LNC that i bought from Lingenfelter. I gotta call them tomorrow and ask if they can send them to me.
how bout scanning the instructions and posting up here?
Old May 14, 2013 | 11:17 PM
swoop's Avatar
I'm pretty sure I got 2 with mine,should have been in the package.
Old May 14, 2013 | 11:37 PM
KTK Z28's Avatar
I didn't see those on the site. I'll have to order those up. Thank you!
I understand what the diodes do and where they go but wasn't sure if it was something specific that I needed... Thank you again everyone. Looks like I just need two... one for the nitrous solenoid and one for the fuel solenoid.
Old May 14, 2013 | 11:42 PM
adamcs's Avatar
Do you have a trans brake? If so you need one there also
Old May 15, 2013 | 01:12 AM
KTK Z28's Avatar
No I dont, the only solenoids that I have are for nitrous and fuel. Not running any type of line lock and trans brake. Thanks again.
Old May 15, 2013 | 06:45 AM
yah man, but i didnt get anything diodes...**** happens and I guess i got a bad packer...LOL
somebody snap a picture of how you ran the diodes.
Old May 15, 2013 | 09:30 AM
badbubba's Avatar
They are not a simple diode. It is a tvs. A simple diode works in only one direction. Order through Lingenfelter website. Very hard to get ahold of them by phone. Will take about a week to get. Use a tvs on each of your solenoids. N2O, fuel, purge, line lock, etc. Wire the tvs in parallel with each solenoid circuit, they are non directional. You can get away with one tvs if your N2O and fuel solenoid are paralled. The tvs supresses the high flyback voltages when the solenoids are turned off and the magnetic field collapses, which causes a spike voltage.
Old May 15, 2013 | 09:53 AM
no way....i called and ordered my LNC and received it in 3 days. just no envelope with these freakin diodes everyone is talkin about.
they must be swamped or something then
Old May 15, 2013 | 03:27 PM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default TVS diode
The instructions are on the web site. Here is a link.
Old May 15, 2013 | 05:11 PM
hey! whadda know, something simple for once...LOL
just one end of the diode on the ground wire and the other end of the diode on the power wire.
I have fuel, nitrous and purge...so i need one for each and they are on their way to me.
