Any negatives to running BR7EF plugs when....
I havent touched anything but the plugs and wires. I rechecked the wires last night and they SEEM tight. What the hell could be causing the car to run like this and with the white smoke? Is it not burning all the fuel for some reason? I have no CEL, but my cats and rear 02's have been tuned out.
Also, just talked to my neighbor who helped me and he mentioned having to use pliers to remove one of the wires because it was on so tight. He said he pulled it so much the wire was turning white.
Idiot.
I may have found my problem. New wires going on tomorrow.
I am surprised its not throwing any codes with a subtle misfire.
What I thought was a slight misfire was not the case..
I took off from a light today and suddenly my battery gauge dropped and the temp started climbing in a hurry. I immediately pulled over and figured I snapped a belt.
Got out and popped the hood and sure enough, the belt was off. However, it was not broken.
After looking around and saw that the main idler pulley was sitting sideways. I was able to take the single bolt out by hand and all the bearings just fell out. Called up a friend who ran to autozone and grabbed one for $50. Spent about 19 seconds putting the new one in, and the belt back on.
No more hesitation. No more "miss". I guess what I was feeling was the bearings going out and causing a very minor drag on everything. It never made a squeek that I heard or anything.
Maybe someone can answer one other thing.. On the back of the old idler was what looked like a spacer, or cover, it was a silver colored disc.. It was chewed up bad, so I didnt put it back on with the new idler pulley.
How important is that part, and does it have a name?
