Flashing SES... Help
Old Oct 19, 2002 | 03:37 PM
nysbadmk8's Avatar
Default Flashing SES... Help
today.. i was just testing out my newly filled bottle... 2 out of the 4 times i sprayed i got a Flashing SES light... on the 4th time i Autotaped a quick 2nd gear to 3rd gear nitrous pull... the flashing SES didnt go off... timing was 22 to 24 degrees, Max kr was 1.0 Both o2's where 890-910... any clues?
its a Nx wet kit 100 shot...
Old Oct 19, 2002 | 04:05 PM
Country Boy's Avatar
Senior Member
Default Re: Flashing SES... Help
DO NOT SPRAY IT AGAIN!!!!
I had that problem once and it was 3 plugs melted. It means misfire and it will kill the motor. Pull all your plugs and inspect.
Old Oct 19, 2002 | 04:09 PM
nysbadmk8's Avatar
yea... i figured... So a Flashing SES is a Mis-fire code?
Old Oct 19, 2002 | 04:12 PM
Senior Member
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nysbadmk8:
<strong>yea... i figured... So a Flashing SES is a Mis-fire code?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yep....
Old Oct 19, 2002 | 04:31 PM
PewterZ's Avatar
What plugs are you using? I hope its not the stock ones. You need to get you a set of NGK TR6'S. Spraying on stock plugs is a NO NO. <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
Old Oct 19, 2002 | 08:44 PM
nysbadmk8's Avatar
yea its on TR6's at 40 gap... maybe they have opened up a bit i got about 4000-5000 miles on them... i will swap them out on tuesday
Old Oct 20, 2002 | 05:46 PM
Chris Spiess's Avatar
<strong>So a Flashing SES is a Mis-fire code?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not specifically, but it is a DO NOT DRIVE THE CAR code. GM's offical line on flashing SES is to park it and have it towed in. Of course, since you get it only when spraying, you obviously have isolated the problem.
Old Oct 21, 2002 | 08:02 PM
nysbadmk8's Avatar
What? flashing SES means do not drive the car??? i use to get it when my o2's where out of wack at every stoplight... i still get it at stoplights once in a blue moon?... i just think its a misfire code... but ok...
Old Oct 23, 2002 | 11:43 PM
2001CamaroGuy's Avatar
<strong> i just think its a misfire code... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think thats what they are saying.....misfire code....but they are saying that a misfire code while on juice is BAD!!!!!
aka: Don't spray anymore untill you figure out WHY its misfireing
Old Oct 24, 2002 | 05:32 PM
Zturd's Avatar
Keep us posted on what you find. I'm sure everyone would like to know symptoms and diagnosis with anything to do with N20.
Old Oct 24, 2002 | 05:54 PM
nysbadmk8's Avatar
it was a Ls1-edit glich... plugs where fine
Old Nov 2, 2002 | 01:36 AM
Austrian Vette's Avatar
I had that flashig SES light also, but the only code I got was "Bank 2 Sensor 1 high voltage (rich)?!?!?!?
What codes did you get???
<small>[ November 02, 2002, 01:49 AM: Message edited by: Austrian Vette ]</small>
Old Nov 3, 2002 | 10:02 AM
BYBYC5's Avatar
*Bad Trader*
flashing SES light can/will flash without setting a code, its a "multiple misfire on a specfic cylnder(or a couple diffrent ones)OR a catastofic emisions problem. ( read the last one in a manual somewhere) its mostly a misfire when it happens tho......if it only happens when you spray its most likey due to insufencent fuel or your blowing out the spark( i doubt that one) it happened to me a few time, changed plugs and went on my way, sprayed again and now im replacing rings, so i say CHECK EVERYTHING.... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Nov 11, 2002 | 02:06 AM
CAT3's Avatar
Restricted User
I about sh*t this weekend. Went to spray a 100 wet shot, and the car immediately fell on it's face simultaneously tripping the flash of death. A 1/4 mile seems so long witha flashing SES. As soon as I rolled around the turn off, I figured it out. I left the bottle closed, flooding the engine with excess gas, ooooops. Good thing that's all it was. Bad thing it was during the fastest street car shootout in Hawaii, racing a teammate in brackets....doh!!!!
Charlie.
