abs inop
Old Oct 20, 2002 | 09:54 AM
strippedSS's Avatar
Default abs inop
abs inop light on after window switch install, any ideas?
Old Oct 22, 2002 | 02:06 AM
383LQ4SS's Avatar
Default Re: abs inop
Still having this problem? Check all your fuses?
Old Oct 27, 2002 | 08:34 AM
strippedSS's Avatar
fuses are all good.
Old Oct 27, 2002 | 09:24 AM
Racehead's Avatar
Have you actually driven the car since this light came on ? I've had my abs light come on twice now. Once I was in the middle of a lapping day and all I had to do was shut the car off and restart it and the light went out. I suspect the abs motors simply overheated. The other time was in my garage, I was bleeding my brakes and when I was done I pushed very hard on my brake pedal to see how it felt and the light came on. I tried starting and restarting the car. Also tried disconnecting and re-connecting the battery, but the light stayed on. Finally I drove the car and as soon as I got over about 10 mph the light went out.
Old Oct 28, 2002 | 05:08 PM
strippedSS's Avatar
I have driven the car, checked all fuses, and disconnected the battery, the abs inop, service viehecle and red brake light all come on periodicly. Its been happening for a little over a week now. Waiting on my predetor. Maybe this will help diagnose.
Old Oct 28, 2002 | 05:43 PM
WMSuperSport's Avatar
having the same problem...gonna check all the wiring that goes to the brakes.
Old Oct 29, 2002 | 02:13 PM
Nitrous97's Avatar
I have the same problem accept abs inop is on and the brake light will blink. MY ses light came on also. I checked the code and it was maF sensor. I havent got to check yet but all this happened after i installed headers on my car along with msd digital 6. I was told it might be related to a problem with burt wires on the pass side by the header. Any thoughts on this. I know that based on the wiring diagram for the car the maf ground ends up on the right side of the engine block. I finally pulled the fuse on my brakes and left it out. I was hearing a ticking sound from underneath the hood. It was electrical because when i pulled the fuse it stopped. Email me if you can help me. @ supacharged21@aol.com <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
