Need Help with MSD Window switch
Old Oct 22, 2002 | 06:22 PM
TXNC5's Avatar
Default Need Help with MSD Window switch
I have an MSD Window switch. I have a 2001 C5 6sp. MSD said they needed to "adjust" the switch to properly work with the LS1.
I was told to simply snip the red/blue loop wires? This would effectively make it a low voltage switch which is what the LS1 needs? Similar to a 4 cylinder setup.
Does anyone have more explicit info? Is this correct?
Thanks.
Old Oct 22, 2002 | 06:29 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Default Re: Need Help with MSD Window switch
Yes, clip both wires.
Tim
