Stock Bottom End record fell tonight!!!!!
Old 06-01-2013, 04:47 PM
Killer5.3's Avatar
Congrats Andy. I think you will be in the teens or ohs very soon when you get the big jets back in it. Just saw the timing so I assume you had at least the .093 in it. I still think you will end up really close to 9.0 soon.
Old 06-01-2013, 05:51 PM
Carter01's Avatar
Originally Posted by Atomic
Congrats man, could you give some more details about your setup? Cam, heads, intake, shot size?
Thanks! Cam is a TSP Torquer 2, Heads are PRC 225 As-cast 205/160, Vic Jr Intake with Nitro Dave spray bars, 300 shot detuned.
Originally Posted by hotrodT/A
what rear end are you running?
Moser 9 with 375s and a spool.
Thanks man! 9.0s would be nice but she is gonna need some weight reduction that I can't afford right now. That was actually a 99 jet but super low timing to be safe. I just installed the fuel cell so I kept it low to see how she performed. Might turn up the wick when the cool weather gets here this fall.
Old 06-01-2013, 07:06 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Congrats!
That's a nice size nitrous jet!
Old 06-01-2013, 08:52 PM
brandon6.0's Avatar
How u likin that standalone setup?
Old 06-02-2013, 01:24 AM
boostednismo's Avatar
Just imagine some negative DA! Congrats man. I'm sure we can find a way to lower the weight without opening the wallet.
Old 06-02-2013, 03:32 AM
brett walker's Avatar
Congrats man! I for one know what kind of work it takes to chase that goal!
Old 06-02-2013, 10:40 AM
subhumanzz's Avatar
Congrats Andy shes flyin'.
Old 06-02-2013, 11:13 AM
Charles Cyrus's Avatar
Congrats!!
Old 06-02-2013, 11:39 AM
Blackpanther99's Avatar
Very awesome. You should post a vid! Congrats!
Old 06-02-2013, 12:55 PM
Ls_Notch's Avatar
Maybe I'm missing it somewhere but what bottom end is this? And what's it run n/a?
Old 06-02-2013, 01:22 PM
ATVracr's Avatar
Congrats!!
Now that you have the record put the radials on it go 1.teen 60' and an 8 second run.
Its possible and I know you can do it.
Old 06-02-2013, 01:50 PM
  #32
Firehawk441's Avatar
Nice Job. Congrats.
Old 06-02-2013, 02:53 PM
  #33
Killer5.3's Avatar
99 stock bottom end including stock rod bolts. I believe he went low 11 n/a with the new heads. It's in another one of his threads.
Old 06-02-2013, 06:01 PM
  #34
Carter01's Avatar
Originally Posted by shortdog
Congrats!
Thanks you sir!
At first i wasn't quite sure about it but it was my fault. I had some air in the line and almost nipped a plug. Thank God I had a FRPS on the car and it shut the nitrous off before it hurt anything.
Thanks Kevin, I just need a sponsor now to pick me up and offer some free light weight suspension! Hint hint anyone????? lol....
Thanks Brett, I know you know what it's like and I remember you flying on stock cubes as well.
Thanks Eric!
Originally Posted by Charles Cyrus
Congrats!!
Thank you!
Thanks man, a few videos are floating around but for some reason SGMP has not been showing times lately, just win lights which sucks imo.
Mid 11s NA, the converter is SUPER tight and won't 60ft at all NA. 2000 rpm shift extensions NA.
Originally Posted by ATVracr
Congrats!!
Thanks Wayne, I know the mph is there. Now I just have to figure out the least expensive way to slay this next dragon, Mr 8.99!!!
Originally Posted by Firehawk441
Nice Job. Congrats.
Thank you!
That is correct sir, stock rods, rod bolts, pistons.
Old 06-02-2013, 06:39 PM
  #35
brandon@nitrousoutlet's Avatar
Nice!
Old 06-02-2013, 08:05 PM
  #36
ronn25's Avatar
Awesome! Its amazing what can be done with a stock LS bottom end.
Old 06-02-2013, 08:17 PM
  #37
nocooler's Avatar
Nice job man!
Old 06-02-2013, 08:44 PM
  #38
loosews6's Avatar
You leaving on all 300 or u have progressive. what kind of center section u running in that 9inch to leave on 300...
Old 06-03-2013, 11:52 AM
  #39
Nitro Dave's Nitrous Outlet's Avatar
Congrats Andy! I knew it was a matter of time before you took that record. You were not far off from it with less parts. I knew the intake swap and the spray bar would take the lead! Great Job!
Dave
Old 06-03-2013, 12:13 PM
  #40
ls1curt's Avatar
that's awesome! congrats
Quick Reply: Stock Bottom End record fell tonight!!!!!
