Nitrous Rookie
Old Oct 29, 2002 | 12:36 AM
Z28_KID_02's Avatar
Default Nitrous Rookie
My friend just bought him a 2001 Z and he is thinking if he could just put a Nx kit on it and leave it just stock with out other mods and if so what does he need and what times do yall think he would run
thanks <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Oct 29, 2002 | 09:37 AM
redsscamaroboy's Avatar
Default Re: Nitrous Rookie
well your friend is going to have to change his stock sparkplugs to non platinums. Then i personally would put in a fresh fuel filter just to be safe.And start small with jetting and either have an autotap set up handy to check everything out or get a tech2 scanner and check things out ie o2 readings and knock sensor readings. If everything goes good you can pick up a ton in the quartermile. I ran 13.53@102 all stock and then 11.85@115 with a 150 wet shot on Nittos. I also ran 12.10@113 on 100 dry shot and Nittos. Good luck and don't rush it. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Oct 29, 2002 | 01:33 PM
First off is your pals car a m6 or a4? auto matics don't require a window switch set up like the manuals do. I personally don't have a window switch. I spray a fogger nozzle right before the throttlebody. i run the stock mass air meter and
a Tech 2 is a scan tool used by GM dealers but is now availible to buy for private use. I use a push button for activation and wait till about 2500 rpm to spray,that helps traction and saves the motor a lot of grief too. To turn it off let off the button. My kit is a converted NOS set up.with purge and bottle heater.All components are NOS. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> (i started out with a 5177 kit)
<small>[ October 29, 2002, 01:35 PM: Message edited by: redsscamaroboy ]</small>
Old Oct 30, 2002 | 12:53 AM
Z28_KID_02's Avatar
What kind of setup do u have the twin nossle or single nossle , maf setup and how do u put in that tach 2 setup and where can he get it. what about the window switch when would turn the nitrous on and turn it off thanks for all the help
