nitrous/fuel jet question
Old Jun 13, 2013 | 06:53 PM
scantone1's Avatar
Default nitrous/fuel jet question
I have a 408 iron block 225 tony ported heads 95 fast intake 9inch blah blah blah 11.1 compression flat top diamond rings with hellfire rings. question I haven't used the juice yet i bought it like this and I was going over everything and found my stand alone for the c16 that i figured was running low pressure since my jet sizes are as follows
73N
52F
I have a pressure gauge that i purchased for it and its up to 15psi when I turn the stand alone on im way over 15 psi. Im purchasing a gauge to 60 but why would it be so high? Its on br 7s 200 shot.
Old Jun 13, 2013 | 07:30 PM
Silver408z's Avatar
Your stand alone might not be setup for low pressure. Mine is setup for high pressure. Pretty sure my jets are 78 55 or 52.
Old Jun 13, 2013 | 07:37 PM
scantone1's Avatar
It must be but when I looked at the Nitrous Outlet Chart my fuel jet size according to that chart says its about 10 psi. I have a nitrous outlet plate.
From what i was told mayhem motorsports tuned this car in North Carolina guess i should ask them about it.
Kinda scared to let it drink the juice... guess I should just go to the tuner before i go for it
Old Jun 14, 2013 | 09:07 AM
brandon@nitrousoutlet's Avatar
Those gauges aren't very accurate. They can build up pressure internally and show the wrong pressure. Its really just a reference to make sure the pumps working.
