NX wet kit wiring diagram
Re: NX wet kit wiring diagram
Ok, I can't find my sh*t either, but here is the verbage edition:
Relay- green wire goes to one of the two solenoid wires for each solenoid
white wire- goes to ground
black wire- goes to 12v, I used the Batt terminal next to the fuse/relay box on drives fender
red wire- WOT switch (don't know if it matters but mine is hooked up to the small straight terminal on the switch not the longer 'L' shaped spade.
solenoids: run one wire from each to the Green wire from relay.
run the other wire from each to ground (doesn't matter which wire from the solenoids)
WOT switch: red wire from relay to the small straight terminal.
blue wire (or whatever color available) from the activation switch goes to the other terminal on WOT switch.
Activation switch: one wire to 12v switched
one wire to ground
wire from WOT switch to the acc. terminal.
That's it man. I will find it someday, probly when I'm retired or something. But, I referenced my setup and it works just fine. Good-luck.
Charlie.
one wire to ground
Charlie.
Not a problem. One trick setup for activation switches, if you havent already seen/read about it, is to remove the camaro tag on the center dash surround and place a foglamp switch w/pigtail for activation and an asr switch and pigtail for purge. noone will ever know what makes you faster or whats different when looking at the switches. Just a thought. If you do use em, shoot an email and I'll give you the lowdown on which wires for what. Good-luck. I just ran a new best tonight on DR's w and w/out N2O, and I spanked a Z06.
Charlie.
Charlie.
I can do that without removing my Camaro tag <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I dont have fogs or asr <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
