Got a plug...help lol
Last time I ran the car was in December and car ran good. 6.90's
I sold the car in March. Ended up buying the car back. Last owner is a friend and said he didn't ever spray the car.
Went to the track last night and car ran terrible on motor so I came home to check it out.
Tip is completely melted away on #1 cylinder and plug is really black and looks oily too.
I would've thought that tuneup would've been safe as I'm hitting the TA with the exact same thing and no issues.
But who knows.
What about oil consumption? I'm sure the plug look liked that because of it not firing properly.
Car does use oil like most h/c cars
I would do a leak down/compression test. As nasty as that plug looks I think you got some ring issues.
I would go back over the tune up and re check everything.
Dave
I will lay off the spray till I figure it out.
I wonder if it could've been the fact when I set it up was last summer and da was 3500 and when I ran in December it was 300. Car ran a lot faster in winter but I didn't think to pull more timing. My tuner said I may not have to pull any for a 100, oh well.
I went over everything and replaced plugs and wires as wire on that cyl looked corroded. Took it to track and made some motor hits and all normal and plugs looked fine.
Tried a nitrous hit but pulling 6 degrees ( I had BR6's gapped .032") and it ran great. Plugs looked good, but like it needed more timing. Made another hit pulling 5 and mph went up, plus still looked good so I called it a day.
