New to LS nitrous. Couple quick ???
Old Jul 12, 2013 | 08:11 PM
bowtieboySS427's Avatar
Default New to LS nitrous. Couple quick ???
Who has the fitting so I can pull fuel from my schrader valve? Will NOS super powershot selenoids work for fuel and N20? Identical selenoids.. Or should I get selenoids that can support my Nitrous Outlet 90mm plate up to 200hp? Since the Super powershot noids I see are only good for 150-175... AND, if I did buy new selenoids, could I use a superpowershot as a purge?
Thanks in Advance.
Old Jul 12, 2013 | 08:18 PM
jblankenship's Avatar
You can use any nitrous solenoid as the purge. If you dont plan to go over 150 hp the solenoid is fine. The fuel rail fitting is 4 an and you can get a schrader valve removal tool at any auto part store. So you just run a 4 an line off the rail to your fuel solenoid with an 1/8 npt to 4an fitting.
Old Jul 12, 2013 | 08:26 PM
Sweet! Didn't know it was that easy. Thanks man
