Melted BR7EF's *VIDEO*
Old Jul 19, 2013 | 08:17 PM
Carter01's Avatar
Originally Posted by ATVracr
Thats dumb!
Well get some heads that use gasket seat then. LOL!!
#9 will work just have to keep timing low.
#10s will work just fine. All you have to do is smash the gasket flat. I usually screw them into a old head I have laying around so i can watch it closely to ensure it is flat. I do all 8, gap them and then put them in my car. Very easy yet effective trick to run 10s.
Old Jul 19, 2013 | 08:20 PM
89L98T56's Avatar
What do you mean "smash the gasket flat?" Give the plug some torque so the gasket forms to the tapered seat?
Old Jul 19, 2013 | 11:04 PM
Carter01's Avatar
Yes, pretty much. Do you have a old head laying around? If you do just screw a normal tapered seat plug in and torque down. Then screw a gasket seat beside it. then see the difference. Then screw the gasket seat down about another turn or so, maybe a little more and the gasket will start out kind of like a o-ring then after torquing it down it will be almost 100% flat. Then look at the tapered plug in the head from the valves side vs the gasket, they are identical.
