Not picking up like it should
From my experience a 16 ft main feed line starts to show flow restriction around the 250 mark, so upgrading to a 6 an main feed line would be a good idea.
What is the compression ratio of your engine?
What fuel are you running?
What heads?
Did you happen to pull the plug at all?
Do you have a wideband on the car?
What do you call good bottle pressure?
Dave
Running 110 race gas
I checked all plugs none had timing marks on the band and they were somewhat fat
I do have a wideband but I have to get the software working to data log it since I just got a new lap top and don't have the install disk anymore
And bottle pressure was all right around 950
Can you post up some pics of your plugs? That way we can look at them and get a better assessment of what's going on.
