Can I use the N20 Tuner with this setup?
Old Nov 22, 2002 | 09:03 PM
T/A Medic's Avatar
Default Can I use the N20 Tuner with this setup?
I was reading the instructions online and I am not sure if it will work with my set up... basically I have it hard wired with full throttle switch... battery--arming switch--WOT switch--to both fuel/N20 noids... any one know if the tuner will work with this set up? Where would I hookup the white and grey wires?
Thanks Jason
Old Nov 22, 2002 | 09:11 PM
Country Boy's Avatar
Senior Member
Default Re: Can I use the N20 Tuner with this setup?
you need a relay in there!!! Thats alot of amperage to draw through those switches.
