Window Switch install questions?
Old Nov 24, 2002 | 09:40 AM
Yetizod's Avatar
Default Window Switch install questions?
After the full installation of my NX Wet Kit, GenX2 and all the accessories it doesn't work at all. Good bottle pressure, all the switches work, we tested power to the WOT switch, Fuel Pressure Reg, and window switch. Even accidently triggered the solenoids at one point. As far as we can tell there is only two possible problems with the install that can be causing my woes.
1. My car is a 2001, and only a 2000 shop manual was available, so we used the tach lead to the window switch based on the 2000 cars. Does anyone know for sure if they are different? If so what pin is it, and what color is the wire for the tach lead on a 2001?
2. If we are already using the the right wire as the tach lead, than the window switch must be faulty. Now I didn't buy it used, the guy who installed it said he's heard of them being faulty out of the box, anyone else ever heard of this?
I know I didn't get into a lot of detail about the troubleshooting of the system after it didn't work, but if anyone else has some ideas on what could possibly be wrong, we believe we've covered everything and we're open to all possible problems. I just want it to work. Thanks a lot everyone for any help you can offer.
Yetizod
Old Nov 24, 2002 | 01:50 PM
Jay Johnson's Avatar
Default Re: Window Switch install questions?
Test each component individually, but you'll have
to really know your wiring(don't fry the components).
Don't forget that the FPSS will need running fuel
pressure to complete it's circuit.
If the car is not running(or the pump is not keyed
on) the fuel pressure will not be high enough to
successfully test it.
Jay Johnson
Old Nov 25, 2002 | 12:20 AM
slow's Avatar
you will need to cut the 2 loop wires on the MSD switch, to put it in 4 cylinder mode, as thats how the output of the LS1 tach is in.
99-02 all use the same tach lead.
Just us 98 cars are different (and 97 for the vettes)
Hope this helps <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ryan.
<small>[ November 24, 2002, 12:26 PM: Message edited by: slow ]</small>
