running WAY rich on 150
Old Aug 10, 2013 | 12:27 PM
Killer5.3's Avatar
Originally Posted by FiFdYnUtz
We run high bottle pressure quite often, I dont really see that being the issue with anything, im picking up ~11mph, and not a very big difference in mph gained on the back half on spray vs. On motor
You should be picking up 28-30 mph between 1/8 and 1/4 on the spray. Motor should be around 23-24 mph usually. Have seen some 6 speed cars pick up 25-26 mph on motor. I'm just saying I would fix what is wrong first and that is your motor tune and your bottle pressure needs to be a consistent 950. My car is tuned to 12.8-13.0 at the track on motor and I run the NO plate at 950 psi bottle pressure ,off the rail fuel pressure and have never had an issue with with mine being rich on any of the jetting I have run all the way up to .093 jet. Not saying that getting your motor tune to 12.8 -13.0 is gonna magically get you afr where it needs to be on nitrous , but, it would be a good start. Good luck with it.
Old Aug 12, 2013 | 09:43 AM
brandon@nitrousoutlet's Avatar
If the motor is rich off the bat then you will be battling that within your nitrous tune up. Your jets will be a lot smaller than what is recommended. I suggest jetting down and then fine tuning with fuel pressure as others have said. Let me know if I can help!
Old Aug 12, 2013 | 09:13 PM
FiFdYnUtz's Avatar
Im running outta jets to try lol, going to order a NO jet pack this week and test again asap...ill report back
Old Aug 13, 2013 | 09:52 AM
87silverbullet's Avatar
Down the fuel pressure if you can. That's free compared to buying jets
Old Aug 15, 2013 | 12:38 PM
FiFdYnUtz's Avatar
How low can I go safelyfor pressure with the high pressure spring?
Old Aug 15, 2013 | 12:49 PM
That depends on your regulator.
Old Aug 15, 2013 | 05:57 PM
boostit5.3's Avatar
i think you need to get your n/a tune straight first afrs should be mid to low 13s, then when you spray it it may be perfect (or closer than pegged at 10)
Old Aug 20, 2013 | 07:44 PM
FiFdYnUtz's Avatar
Did some testing/tuning tonight and managed to get it around 11.9-12.00...thats with a 20F jet 62N jet and 45psi fuel pressure
Old Aug 30, 2013 | 10:20 PM
screamin88's Avatar
I had the same problem. I found I had a plugged nitrous filter. Just throwing that thought out there..
Edit**
Yeah, Make sure the motor is running prime before you worry about nitrous tuning..
