75hp pill and shifts
i just installed an nx wet kit..set it up with 75hp jets...i see that everyone is running 100-150hp shots and spraying through shifts...will a 75 be safe? thanks in advance
ls1 edit
ls1 motorsports lid
vig 3200
mac y-pipe
cut out
1.65 60ft
12.27@110.56
no nitrous pass yet
99 firebird formula
ls1 edit
ls1 motorsports lid
vig 3200
mac y-pipe
cut out
1.65 60ft
12.27@110.56
no nitrous pass yet
99 firebird formula
Re: 75hp pill and shifts
I have pretty much the same set up as you do with a 75Lb shot also. I have the window switch set up to start spraying at 3000 and off at 6000. I spray from the tree to the trap, you'll be fine.
P.S, <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> Sorry I just remembered I raised the shift points to 6400 RPM so I'm not spraying thru the shifts and probably wouldn't do it.
<small>[ December 08, 2002, 09:49 AM: Message edited by: Elite_Hot_Rod ]</small>
