Head Gasket Recommendations
Old Aug 9, 2013 | 03:17 AM
JJ_TURBO's Avatar
11 Second Truck Club
Default Head Gasket Recommendations
I'm looking to finally finishing my 383 stroker ls1 with wiseco pistons #K6464X3903, Darts 225's, 64cc chambers and wanted some suggestions as to which head gaskets to use? looking to spray 200-300 shot, I was looking at the cometic c5745
Old Aug 9, 2013 | 08:28 AM
ATVracr's Avatar
We have always used cometics and never had any issues.
Old Aug 9, 2013 | 10:35 AM
Carter01's Avatar
Cometic
Old Aug 9, 2013 | 01:17 PM
WhiteLTone's Avatar
Cometic is good. I used ls9 gaskets with copper spray. Just make sure to tq them properly and re torque after a heat cycle or two
Old Aug 9, 2013 | 01:31 PM
WhiteLTone's Avatar
Old Aug 10, 2013 | 04:06 AM
JJ_TURBO's Avatar
Been reading about the ls9 gaskets but I think I'll go with the cometic since the 3.910 bore size its closer to the 3.905 cylinder and also they have several compressed thickness available which now I have to decide on that, what do you guys think I should go with? should I go as far as .066 or .075 for a better quench?
Old Aug 12, 2013 | 02:24 PM
ATVracr's Avatar
.075.... opening the quench will open tuning window a little.
Old Aug 14, 2013 | 10:36 PM
JJ_TURBO's Avatar
That's what I read from some of the post you have done, and so I will go with the .075 cometics, thanks for the help...
