Mounting bottle in spare tire area.
<small>[ December 23, 2002, 06:48 PM: Message edited by: Jamie99TA ]</small>
Charlie.
<strong>Thanks cat3, pics would be great!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would like some pics also. SSDriver@earthlink.net
Let me know which bottle you have.. Again if it's the 10lb I can help you out but the 15lb. Good Luck!
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
PS, since i dont know how to post a picture i will e mail it out to ya'll.
Happy Holidays, Charlie.
No drew778, the rear seat does not work so well, thats why you wont be running (legally)in any $$$ events. Just mount the bottle will ya! Rex has a remote bottle opener he'll sell ya (if I dont buy it first) brand new in box, so you can mount your bottle and still fly around the roadways. C-ya fried-day.
Make sure when you clamp it back down, the line is tight and you have the line facing down so the siphon tube will be in the right position, if it is canted a little you wont get the full effect.
Also, use the thread sealer on all connections except the following: bottle fitting/line and the fitting at the jets. All other connections need the sealer. And make sure if you want to spray to double check that the bottle is open, I left mine closed one race, against a friend but it was for money, and tried spraying outta the hole, kinda flooded it since the wet kit was spraying the hell outta the fuel nozzle side. Good-luck.
Charlie.
10lb BOTTLE PIC 1
10lb Bottle Pic 2
As you'll see all I did was run down to the hardware store and bought a strip of I'm guessing galvenized steel.. Not really sure.. You can bend it. Anyhow It bolts perfectly to that Antenna Mount and runs right across the tire well opening. Just drill a hole and secure the other side. for the other strip I connected it to a stud that pertrudes into the Well. I'ts the Bumper Trim Bolt. I had to bend the strip at appropriate length since it sits a little higher than the Antenna bolt. It will all make sense when you look in there. After that just bolt your Bottle to those strips and Walla!
<img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" /> Yeah I know it looks wrong but that's actually how venom does things (Dry). The Control unit in my Glovebox is tapped into the O2's to monitor A/F ratio. Each injector is also tapped by the venom control unit. After an 02 diagnostic check the system goes into a ready state and when enabled it pulses the Injectors for the extra fuel all the while maintaing proper/safe A/F Ratio. If the System should detect a lean situation it stops the flow of N20 immediately! It's a pretty cool little setup. I just gotta get a bottle warmer though!.
