How Did The Nitrous Outlet Stinger Plate Testing Go
That's correct, I'm had a band issue with the glide. Just needed some adjustments. I went 125.50 on the 82 pills with this new motor.
Dallas Raceway clocks are known to be slower in one lane vs the other. I never tried to run the other lane. The mph isn't what really matterd to me.
There was a couple of factors to weigh in here, the trucks roughly 150 pounds heavier then before. This one runs 111 vs 105 on motor alone. The band issue was a clear factor as I too believe it should have went faster. If you watch the video, listen to how you never here it change gears.
