Big thanks to ATVRacer, Carter, John at Nitrous Outlet
I just wanted to thank these guys for giving me some advice on spraying the 200 on the stock bottom end in my 2010 Camaro SS. I already had gone 10.87 on motor in the spring, but I swapped cams and even despite the da being almost 1000 ft worse, I still went 10.75 @ 126 on motor. Not to bad for a stock bottom/stock head car @3660 lbs.
So then I crack the bottle open, and on my third nitrous pass ran a 9.99 @ 138.56 launching in second gear (6l80 trans).
I know I shot some pms over and talked to John at Nitrous outlet as well.
So thanks guys for the advice, took a little while to get the tuneup right for the gas, but it was worth it. And once I fix my posi, Ill go faster, only had a 1.48 on the gas. Ive been that on motor before....lol.
