Timing tuner n2o controller
Old Oct 31, 2013 | 11:30 PM
jcuadra's Avatar
Default Timing tuner n2o controller
Does anyone have any experience or feed back on this controller? I wanted to get some opinions from people who have used it before I buy it.
http://www.fullthrottlespeed.com/ite...METUNE+eq++Tp+
Old Nov 1, 2013 | 01:34 PM
jcuadra's Avatar
Anyone?
Old Nov 4, 2013 | 02:53 PM
ShiznityZ28's Avatar
We used one on a hidden shopt car. worked well. this was a few years back. didn't have as many options then.
Old Nov 4, 2013 | 03:27 PM
87silverbullet's Avatar
Look into the Lingenfelter LNC 2000. Its easier to install and shows up in HPT
Old Nov 4, 2013 | 03:36 PM
jcuadra's Avatar
Well it turns out this controller will not work with a 58x reluctor. What I really want is a controller that will pull timing when the nitrous is armed. So I can ride with full NA power when it isn't armed.
Old Nov 4, 2013 | 03:46 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
MSD can get you set up with this, and I have also heard good things about Lingenfelter. They can get what you want done, done for you.
-Garrett
Old Nov 4, 2013 | 04:07 PM
LNC doesn't need a crank signal so it does both, 24 & 58 tooth. It has a trigger set up too. It will only pull timing when you are on the nitrous.
Old Nov 4, 2013 | 04:32 PM
brandon@nitrousoutlet's Avatar
This. In conjunction with an NOS Mini, you will have a nice setup!
