Running hose and install Q
Old Jan 24, 2003 | 12:48 AM
LS1Formula98's Avatar
Default Running hose and install Q
Well, I will most likely be installing my nitrous this weeknd, so I have a few Q's. First, I am planning on running the braided lines on the inside of the car. Where did eveyone else run the hose? Under the carpet along the side? I am planning on mounting the bottle in the back seat between my 2 seats (on the hump) Is there anywhere online where I can see pics/direction on how to run the line? Next, has anyone got any good recommendations on how/what to use as far as mounting the bottle in the back seat? I want to angle it up like at a 45 degree type angle. I need some ideas on brackets and hardware to use. Any thought and ideas are greatly appreciated.
Old Jan 29, 2003 | 12:14 AM
2000 Camaro SS's Avatar
Default Re: Running hose and install Q
Hope it is not to late.
<img src="http://groups.msn.com/_Secure/0RgAAAAMVMOYNIWF!src2auPkxpxIHpzW8Ydy38LafcEMzuCZP 4YpORtFkfhhN83dYQfJDq07Pkm22LBOw4rdIbjgUMh4q3NfjgQ vQR8!3Ic/Cage1.jpg?dc=4675345568909592822" alt=" - " />
I cut two peices of wood. One for the front on for the back. The front one is taller than the back. I made it to fit the curve in the floor. I ran my line under the carpet and along the door trim (onder the trim) BUT>>>> this is not legal! it needs to exit the car straight down and go under the car to the front. I think this is how I read it. I might be wrong on that but it is something to look into. I hope the photo is clear enough for you to see what i'm talking about.
