Dry kit tuning issues....
Old Jan 29, 2003 | 05:30 AM
Ghost SS's Avatar
Default Dry kit tuning issues....
I just got ls1edit and have a friend(Nic Dejardins) tuning my car. I have full exhaust(hookers and true duals), descreened stock MAS, and a lid. I have in the 90 jet currently. On motor my A/F was about 12.5:1, but on bottle it went really lean...13.8:1 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
So why the hell isn't my computer adding more fuel when needed? I have no clue when it comes to this tuning crap but I want to learn. Tuning was done on 91 octane, that's the highest we can get at the pump <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> I heard the on Hooker LT's the 02 sensor isn't all the way in the exhaust stream...could this be causing my problem? Do I need to grind down the 02 sensor bung? Any info would be appreciated!!
Old Jan 29, 2003 | 09:03 AM
NicD's Avatar
7 Second Club
Default Re: Dry kit tuning issues....
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ghost SS:
<strong>On motor my A/F was about 12.5:1, but on bottle it went really lean...13.8:1 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Honestly I think its the single nozzle you are using. I would try using the dual setup at adjacent ends of the lid firing at each other and see if that helps the MAF "see" more. Its got to be something like this IMO. This is one reason I don't like dry kits, no adjustability.
<strong>I heard the on Hooker LT's the 02 sensor isn't all the way in the exhaust stream...could this be causing my problem? Do I need to grind down the 02 sensor bung? Any info would be appreciated!! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't think its causing your problem. Usually you would throw insufficient switching codes if your O2 sensors weren't all the way into the exhaust stream. Then you would have to grind down the bung to get the O2 sensor more into the stream. But you are not having that problem so thats not it.
<small>[ January 29, 2003, 09:04 AM: Message edited by: Nic00Z28M6 ]</small>
Old Jan 29, 2003 | 08:30 PM
DONAIMIAN's Avatar
I'd grid down the O3 bung anyway to be on the safe side. It could be that the O2 sensor isnt all the way in and the computer learned it out, then when you spray, the spray isnt being flushed through the engine long enough for the computer to learn it out. Try that first and if that dosent help try the dual set up. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 29, 2003 | 08:59 PM
B18B1LS1's Avatar
My car has always ran lean on my dry shot. I have to use my MAFT and add a lot of fuel to compensate. Even on a 100 shot I was getting 3.9 degress of KR.
Jeffrey
Old Jan 29, 2003 | 11:27 PM
98,Ram,Air's Avatar
Do you mean a .90 jet or a 90 hp jet? If .90 thats about a 200 shot I would guess. Too much juice...
Old Jan 29, 2003 | 11:34 PM
Ghost SS's Avatar
90hp jet...I actually got 83rwhp and 121rwtq from the jet so that was pretty nice <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 30, 2003 | 12:53 AM
NicD's Avatar
7 Second Club
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong> I'd grid down the O3 bung anyway to be on the safe side. It could be that the O2 sensor isnt all the way in and the computer learned it out, then when you spray, the spray isnt being flushed through the engine long enough for the computer to learn it out.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What? That doesn't make any sense at all.
Old Jan 30, 2003 | 05:30 PM
DONAIMIAN's Avatar
02 sorry, didnt see that <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Jan 31, 2003 | 12:34 AM
004mula's Avatar
You know, the O3 bung. It's right behind the O1 and O2 bung. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
