NX Window Switch
Old Jan 30, 2003 | 07:58 PM
Sears's Avatar
!Dial-up Director
Default NX Window Switch
Does NX make a window switch? I can't seem to find one from them. What window switch are you guys using with your NX MAF kits?
Also do you want the window to close right before the shift or set it a little higher then the shift? M6 tranny..
Thanks,
Justin
Old Jan 30, 2003 | 10:19 PM
RUF SS's Avatar
Default Re: NX Window Switch
I have the NOS window switch. It is the same unit as the MSD window switch.
Old Jan 30, 2003 | 10:41 PM
Kobwo's Avatar
NX Sells one.
Old Jan 30, 2003 | 11:57 PM
Jason99T/A's Avatar
I can shift faster than you.
Justin, we have had good luck w/ the MSD window switch. We have some in stock at the shop if you need one.
Jason
Old Jan 30, 2003 | 11:58 PM
Jason99T/A's Avatar
Are you hooking the kit up yet? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 31, 2003 | 05:41 AM
Sears's Avatar
!Dial-up Director
What kit? I am asking for a friend. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Kobwo every dealer I have emailed said that it is not in there 2003 NX catalouge?
Justin
Old Jan 31, 2003 | 09:41 AM
xaon's Avatar
I've got a harlan window switch on mine. It works well. Use a MSD window switch on my dad's car and it works good also. I have not ever seen an NX window switch and every NX 'package' i've seen usually comes with a MSD window switch (and sometimes a mallory).
I have my window switch set to turn off after my shift point, but before the rev limiter.
Old Jan 31, 2003 | 10:23 AM
Kobwo's Avatar
I live in Wichita Falls and installed a nitrous kit on a friends car. He drove over and got it (window switch)from NX themselves. He paid nitro dave's for it though. It had a big white sticker on the side and was labeled NX. It has a picture of it in the NX install manual as well. It could have been the MSD with their label on it but I don't think MSD would allow that. I'll call NX standby,,,,,,,,,,,,Talked to Jeremy at NX, it's the(NX RPM Activated Window Switch Part # 18959) Good luck with the spray!
P.S. Nice Avatar
<small>[ January 31, 2003, 10:26 AM: Message edited by: Kobwo ]</small>
Old Jan 31, 2003 | 04:41 PM
Futral's Avatar
Justin,the MSD one works good,and basically are all the same unit.
You want it to turn off after the shift and before the rev limiter.
Old Jan 31, 2003 | 06:35 PM
Sears's Avatar
!Dial-up Director
Thanks guys.
Justin
