Where to run bottle line?
Old Jan 31, 2003 | 08:46 PM
unit213's Avatar
Administrator
Default Where to run bottle line?
I have the solenoid mounted on the passenger side of the engine bay. I believe there is a rubber grommet behind the PCM that I can run the line though. I don't really want to mess with the PCM though. How would I run it through the driver's side? Also, I am going to run it inside of the car, not underneath.
Thanks. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Dan
Old Feb 1, 2003 | 03:26 PM
unit213's Avatar
Administrator
Default Re: Where to run bottle line?
Ok guys, that's exactly what I did. I ran the feed line and the wiring through the grommet behind the PCM. Thanks for the help!
Dan
Old Feb 2, 2003 | 12:04 AM
Toecutter's Avatar
Run it thru the passenger side. This will give you enough line to get to the spare tire well or the luggage area. Remove the plastic trim on the passengers side and start feeding the line from the middle of the door entry. You will have to snake the line under the seat belt bolt. It is tight, but you can do it. Feed it thru and behind the rear seat side panel towards the luggage area. Now work the other side under the kick panel and up to the rubber grommet. You can just cut a little hole or push the grommet out of the way and snake the line thru to the engine compartment. Then just tuck everything where you want it. Tuck the line down in a channel below the trim screw holes and replace the panel. That's it, you are done. <img border="0" alt="[gruffy cottonball]" title="" src="graemlins/gr_gruffy.gif" />
Old Feb 3, 2003 | 12:14 AM
wicked-98's Avatar
I couldn't find it so I drilled a hole in the fire wall <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
