Help with nitrous activate timing retard wiring
Old May 7, 2004 | 04:00 PM
Draco's Avatar
Default Help with nitrous activate timing retard wiring
Hi guys,
I am trying to use a relay and resistor to trick the IAT into thinking the temp is 178* F when the nitrous is activated. When nitrous is not activated, the IAT should read normally.
The thing is, it works fine with the car engine off and ignition on, but not when I run the car up to 3k rpm and hit the gas. In fact, sometimes the IAT plummets instead of pegging at 178*
There are two wires going to the IAT - purple and tan. purple is ground, and tan is PCM signal (5v)
Here is how I have it hooked up by relay posts:
30: Purple wire that was going to IAT sensor was cut and rerouted here.
85: Ground to window switch
86: 12v signal from TPS switch
87a: continuation of purple wire to the IAT sensor
87: wire with 330 ohm resistor inline, spliced into the tan colored IAT sensor wire. This places the line in parallel with the IAT sensor.
Does this sound right? I thought it was fine, and I get a good accurate signal out of 87a, I just cant seem to get the right IAT when post 87 is active instead. Should I have fed the tan wire into post 30 instead of the purple wire?
Here is a quick and nasty diagram... the relay doesnt make much sense but I labelled the pins
Attached Thumbnails Help with nitrous activate timing retard wiring-timing-retard.jpg
Old May 7, 2004 | 04:27 PM
frcefed98's Avatar
Can't really help you out on your problem, but are you done with my crank pin kit?
Thanks,
J
Old May 7, 2004 | 04:30 PM
Draco's Avatar
Thanks,
J
Hey man,
will probably send it back soon... TSP took a few months to ship my timing chain and it just arrived. If you need it back right away let me know and I will ship
sorry bout the delay
Old May 7, 2004 | 04:33 PM
frcefed98's Avatar
Cool, Just checking up
J
