For those of you that spray through the shifts........
Old Feb 6, 2003 | 10:00 PM
The Guy in MY 99TA's Avatar
Default For those of you that spray through the shifts........
YOU CAN KISS MY BOOTY!!!!!!!!!!! I tried it last Sunday and well it DID NOT WORK!!!!!! LOL! Luckly I was only spraying a 75 shot and it didn't hurt anything when I hit the rev limiter(that is set at 6600!) I want to drop my shift points a good bit and try it again if I ever get those timing prollems worked out.
Josh S.
Old Feb 6, 2003 | 10:50 PM
Orange Krush's Avatar
Default Re: For those of you that spray through the shifts........
Josh buddy window switch! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Be safe!
<small>[ February 08, 2003, 05:36 PM: Message edited by: Orange Krush ]</small>
Old Feb 8, 2003 | 01:08 AM
TomQ's Avatar
OrangeK on what RPMs does your window switch shut off the nitrous, so you do not spray through the shifts?
Old Feb 8, 2003 | 04:17 AM
CAT3's Avatar
Restricted User
Word to the wise, raising shift points w/ stock valvetrain and spraying thru the shifts on a 150 shot will tend to bend some valves-noy cheap (my friends experience a couple months ago. Me however, I have all stock tuning, mods in the sig, and leaving it Overdrive I spray 100 shot thru the shifts all weekend long, every weekend absolutely no problems. Most guys that mess with the HPP3 tuning and crap tend to bounce the rev limiter, and or leaving it in Drive vs. OD. Mine did do a bounce when left in Drive. I have sprayed a 150 shot thru the shifts same a 100 but a hella lot quicker!!!
Old Feb 8, 2003 | 07:58 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TomQ:
<strong> OrangeK on what RPMs does your window switch shut off the nitrous, so you do not spray through the shifts? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tom I use a MSD window switch with a 3000 pill on the low side and 6000 on the highside! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 8, 2003 | 11:00 AM
I am gunna put the stock shift points back in and just see what it does. BUT I want to get it to run right on motor first. I think the good weather we have had this weekend might be the trick for some 12.50's on motor. Then I might play with the nitrous a little bit.
Josh S.
