Spraying in 5th gear??
Old Feb 14, 2003 | 02:37 AM
DOC OTIS's Avatar
Default Spraying in 5th gear??
Anybody have any trouble spraying in 5th gear. I am not going to do it all the time. I just want to make a couple of passes with the 150 pills in for a good timeslip and then back it down. I currently have 4:56's with a 28" tall slick so I know I will be well into 5th through the traps. Anyone spraying this combo? Car cut a 1.500 60" on the motor. Think it will hold a 150 shot out of the hole? My guess is I'll need a progressive controller. My goal is to rip off a 9.99 pass w/ a stock shortblock and full weight(3640). Don't think anyone's accomplished that yet, and I probally won't either but I bet I get close. Any help would be much appreciated. Thanks
Old Feb 15, 2003 | 02:47 AM
DOC OTIS's Avatar
Default Re: Spraying in 5th gear??
What do you have to pay for this service. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Feb 15, 2003 | 05:20 AM
383LQ4SS's Avatar
Spraying in 5th gear is not a problem while doing a 1/4 mile pass. But you may be better off getting a gear that will allow only using fours gears. Thats alot of shifting in a small amount of time.
Old Feb 16, 2003 | 12:25 AM
DOC OTIS's Avatar
I want the car set up for the motor, which it is. Majority of the time the car will be on the motor so I don't want to take any gear out of it.
Thank you for the response. I haven't received much of a response from the couple of questions I have asked.
