direct port
Old Dec 31, 2013 | 02:26 AM
ws6guy27's Avatar
Default direct port
Looking to see how much direct port for fast ls7 intake would cost? Or do I need send my intake in? Just trying go cheapest best route
Old Dec 31, 2013 | 09:30 PM
magnum-gto's Avatar
Good luck on that!
Old Jan 1, 2014 | 09:07 AM
87silverbullet's Avatar
If you don't have the money, then save your money until you do have enough money. Its not just as simple as putting nozzles in an intake and calling it a day. Call or Email Nitrous Outlet and let them put a quote together for you because the price will vary not knowing if you need a 1 or 2 solenoid setup and whether you go with a distribution block or a rail system.
Old Jan 1, 2014 | 11:42 AM
jesse92's Avatar
IMO with the FAST it is made a lot easier since it has a place for you to tap already no bungs need to be welded etc. Most expensive part will be the nozzles unless you can go dry....I prefer dry I recently switched from FAST dry direct port to the Holley Hi Ram with a plenum system and I have a distribution block and nozzles if you want to go that route for a FAST no longer in use. Here are some pics of my dry setup in a FAST for you.
Now to this setup but decided not to run any tubes at all since this pic.
Old Jan 2, 2014 | 08:53 AM
brandon@nitrousoutlet's Avatar
Give me a shout and I can get you set up!
Old Jan 2, 2014 | 09:11 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Looks like a spider LOL.
For a decent direct port, with plumbing included it usually runs around 1000+...but it all depends on what power level you are looking for, the type of solenoids etc....
-Garrett
Old Jan 2, 2014 | 08:13 PM
jesse92's Avatar
Yeah I agree it looks like a spider. I had about $250 not including the noids so add $200 for the .125 bottom exit and purge being it was single stage dry setup $450 complete not too shabby imo.
I just do not see the need for 2 nitrous solenoids since most .115-.125 flow 350hp+ alone. It can make more per jet with 2 but unless I am racing a jet limited class why?
