Leash Controller anyone using it on 2 stages?
Old Jan 2, 2014 | 11:54 AM
98blueSScamaro's Avatar
Default Leash Controller anyone using it on 2 stages?
I been looking at controllers and the one that really seems to stand out is the leash. But I need mine to run two stage's. anyone have there stuff on two stages?
Old Jan 3, 2014 | 12:19 PM
GIMPY02's Avatar
I run there single stage nitrous board. Works great and makes everything very simple and clean. I know they have a 2stage programmable timer but that's it. Call and ask. They might be able to make u one for 2stages
Old Jan 3, 2014 | 11:04 PM
Thank's Gimpy. seen your car out end of last year. looked strong. Hit that thing harder and get that 60 lower.
Old Jan 4, 2014 | 03:15 AM
Wildcobra's Avatar
Good info
Old Jan 4, 2014 | 07:43 PM
calling him monday
Old Jan 4, 2014 | 08:33 PM
GIMPY02's Avatar
No problem. Have any questions feel free to pm me..
Thanks we were creeping up on the tune. Still a lot left in it for cam only nitrous setup. The converter is junk which is what's hurting my 60ft. I have no clue what brand it is. I didn't want to buy a converter without having any data to send to who ever I end up having make my converter..
Old Jan 4, 2014 | 08:55 PM
GIMPY02's Avatar
If I can also make a suggestion you can run 2 stages off the nos mini progressive controller without having to buy a wot switch or anythomg . its all in one
http://www.nitrousoutlet.com/electro...ontroller.html
Old Jan 4, 2014 | 08:56 PM
will do and see you at the track.
Old Jan 4, 2014 | 10:55 PM
Canada's Avatar
NOS Launcher will do up to 4.
Old Jan 5, 2014 | 10:37 AM
I wonder how the mini controler is to work. that or the launcher
Old Jan 5, 2014 | 11:17 AM
v8sten's Avatar
I talked to him last week on this very thing. he is working on a 2 stage progressive right now and does not know when it will be released. i told him i need one by feburary cause that is when i plan to rewire my car. all of the other ones are a time based controller, not a progressive. The N2O Leash Single Stage Progressive Controller has a time based aux output and can control a second stage with that. His name is Randy Westmoreland, look him up on Facebook, i just messaged him on there.
Old Jan 5, 2014 | 01:23 PM
GIMPY02's Avatar
To be 100% honest I would spend the money on a holley dominator efi. Reason being no matter which way you go as far as power adders boost or nitrous u can control it right threw the efi system. It has a way to control up to 4 stages of nitrous. Just a thought. Thats what im buying because my car will be a turbo car more than likely next year. No point to spend money on a nitrous controller when I can get a dominator system with a nitrous controller and boost all built in it allready
Old Jan 5, 2014 | 02:48 PM
i was just looking at that because the foggeris setup to be a 2 stage dry and if i go with the holley because then i will just run massive injectors and control fuel that way who knows because i too will be going boost next like all of use in the mid west
Old Jan 5, 2014 | 02:53 PM
my intake as a 2 sage dry before the puck and getting setup to be a wet fogger
Attached Thumbnails Leash Controller anyone using it on 2 stages?-n20-outlet-2-stage-dry-system-super-vic-3.jpg
Old Jan 5, 2014 | 07:16 PM
GIMPY02's Avatar
Its worth it. One of my friends has multiple championships in topsportman. He runs that system on both his camaro and rail car with 4stages of nitrous. I told u exactly what he told me. Plus tuning with holley efi is so simple.
