4.10 or 3.73 when spraying???
Old Feb 16, 2003 | 11:09 AM
jeff's Avatar
Default 4.10 or 3.73 when spraying???
i needed to make a choice last week, either to go with a 3.73, or a 4.10 in my moser 12 bolt that i am getting installed wed @ speed inc. i just got my nitrous installed this winter, so i have yet to run it with nitrous. i talked to larry from speed inc. and he told me 99% of the people that order new rear ends get a 4.10 (M6 owners i mean). i told him that i want to spray, and that it might just be too much off the line. and he told me that well how often do you go to the track, which i will probably only go like 4 times this summer. so i will be doing a lot of street racing, and also a lot of N/A runs. so that is what convinced me into getting a 4.10. get a 3.73 for a lot of track use and N20, get a 4.10 for N/A use.
Also i have some questions that i need answered:
(i will list my mods bellow, so u can see my setup and how much power i have)
1. How bad will i spin if i spray in first with a 4.10 gear (i am only using my 75shot but want to do 100shot)?
2. Should I wait until second gear to start spraying?
3. Am i always going to have to manually hit the arming switch when i hit second gear (my setup is a WOT switch) i mean that will be hard to do, shift from first to second and then flip a switch fast or do they make something that it wont spray until second gear, ive heard something about a mallory switch or something but dont really know much about it?
4. What RPM to drop it in at?
5 What gear will i finish in both N/A and with NO2, and how far into the gear will i finish it in?
1998 Trans Am WS.6 M6
Lid, Borla, Mac Headers w/ offroad y-pipe (02 sims), SLP air temp module !CAGS, descreened MAF, ported MAF, MAFT, MSD window switch, NX wet (75shot),NX bottle heater, MSD spark plug wires, NGK TR6 plugs,BMR SFC's, BMR LCA's, Z06 clutch, 315 NITTO drag radials
Old Feb 16, 2003 | 06:10 PM
Big Mike's Avatar
Default Re: 4.10 or 3.73 when spraying???
Without getting to in depth... First and foremost the ZO6 clutch will not hold up. Go with 3.73's, if you go with 4.10's you will need a 28" tire or you will more than likely finish in 5th gear, and you don't want that!
Old Feb 17, 2003 | 02:45 PM
Zturd's Avatar
I'll 2nd the 3.73s. Thats what I've gone with do to the what Mike said. I didn't want to go to a 28in tall tire. I know if I went to a 150shot there was no way i was gonna make it through the traps in 4th gear. That or you need a good cam thats good for high reves and make your motor ready for that. Plus the 3.73s are awesome on for a pull on the highway with Vettes etc.
