nitrous and breather/pcv set up??
What are most of you all running? I am currently running a oil water separator catch can with the stock pcv system. I am still getting oil in the intake and on the plugs. I know this is bad with nitrous and I have bumped the jetting from 125 to 175ish for this year. I know what the pcv does vs breather but what is the best way besides a vacuum pump to keep the oil out? My only other thought was someone I read about that was restricting the vacuum from the intake with a valve on the line after the catch can. Any help would be great.
You can cap all the pcv crap off and throw it away if you want no oil in the intake track. I ended up capping it all then installed 2 10an fittings on each valve cover and set up an exhaust evac on my car. Runs great and no oil. I spray alot more than you and still no issues yet.
