bolt-on motor with a 200 shot dry
Jeffrey
Spraying 200 is a lot different than 150 especially on a stock bottom end. Set the window switch to come on at 3800 or 4000 rpms, retard timing, run race gas, monitor your o2's via ATAP or scanner. These are just a few pointers on spraying a big shot, I know there are a few others that have sprayed 200 on a stock bottom end and Im sure they will post up sometime soon.
Jeffrey
<strong> Basically it was a heads and cam car (MTI) with 42 lb injectors with programming and a big dual stage dry shot. Stock bottom. I believe he was running low 10s. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm..... you seem to be using 'was' quite a bit <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
