Spark plugs
Old Feb 11, 2014 | 10:22 PM
TexasLS1TA's Avatar
Default Spark plugs
Hey guys need some help choosing some plugs for my nitrous. I have a LQ9 418 with 11.3 compression with LS3 heads I will be spraying 100 or maybe a 150 what would be the best plug to go with. Also won't be spraying that often.
Thanx
Old Feb 11, 2014 | 11:03 PM
HCI2000SS's Avatar
Probably a BR7 would work well
Old Feb 12, 2014 | 04:01 AM
TexasLS1TA's Avatar
Thanx
Old Feb 13, 2014 | 12:33 AM
NITROUS JUNKY's Avatar
I've always used NGK TR6.
Old Feb 13, 2014 | 10:43 AM
boostit5.3's Avatar
theres always that one guy lol.... smh
Old Feb 13, 2014 | 11:40 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
A BR6 or BR7 would be better for nitrous than a TR, because it has a non projected tip on the plug. This is what you want with nitrous.
-Garrett
Old Feb 13, 2014 | 11:47 AM
brandon@nitrousoutlet's Avatar
Right? lol
Old Feb 13, 2014 | 05:41 PM
87silverbullet's Avatar
Originally Posted by brandon@nitrousoutlet
Right? lol
Look at his join date.
Old Feb 14, 2014 | 01:47 AM
4WOFURY's Avatar
With your compression, I would start at at least a B8efs and work your way down. Always better to start cold and work hot (worst that happens is you foul plugs)
Starting hot could turn a plug into a glow plug and predetonate the mixture, potentially popping your engine.
Old Feb 15, 2014 | 07:41 AM
WE TODD DID's Avatar
Thanx
NGk R5671A-8
Old Feb 15, 2014 | 08:50 AM
Originally Posted by WE TODD DID
NGk R5671A-8
That's a gasket seat style plug which still works and is a number 8 heat range plug but NGK b8efs is a tapered seat style plug which is what an LS head is. So, why not use the correct seat style? Now if you are spraying enough, there is no number 10 heat range in a tapered seat and I can then see using a R5671A-10.
