Timing with nitrous....
Old May 11, 2004 | 10:18 PM
Phil99vette's Avatar
7 Second Club
Default Timing with nitrous....
Whats the general rule of thumb with nitrous as far as timing goes?
75 shot
100 shot
150 shot
200 shot
250+ shot
Old May 12, 2004 | 06:36 AM
TOXIC-Z's Avatar
I've always heard 1 1/2 to 2 degrees per 50hp shot, from the mags, not sure how that applies to the LS1
Old May 12, 2004 | 07:03 AM
DERTY's Avatar
The Bull
I found 2 degrees per 50 works well. You may find that you require more timing to be added / removed where your converter stalls a bit. Then you can level it off from there. Then just tweak it from there.
Old May 12, 2004 | 12:36 PM
badls1's Avatar
my buddies car runs on 91 octane pump gas, 26 degrees of timming with 0 knock on power ring w/100 shot. its all in the tune.
Old May 12, 2004 | 03:18 PM
taqwache's Avatar
i ran 26 with a 100 shot dry also and never saw any KR. not sure what a 200+ would work on though.
Old May 12, 2004 | 03:38 PM
DERTY's Avatar
The Bull
Well, 2 degrees per 50 puts you right around 22 degrees which is where I was roughly at. Then I went from 200 to 300 (wet) and was sitting at around 18 degrees or so (give or take a few in some spots).
Old May 14, 2004 | 09:23 AM
Bad30th's Avatar
What about ~94 octane (91 pump mixed with 103 VP racing unleaded), 100 wet shot jetted rich and 26 degrees of timing ? 11.1:1 compression heads/cam...
That's what I'll have unless I buy something to pull timing on the bottle. Should be OK without pulling timing, right ? It's been tested once or twice already... :
Bad30th
Old May 14, 2004 | 10:57 AM
Ed Blown Vert's Avatar
Rob, I shoot 150 on my set-up with 25* . I just make sure I am on the rich side 12:1
Old May 14, 2004 | 11:31 AM
badls1's Avatar
Bad30th
100 shot on pump gas will be enough as long its tunned right, mark did your tune right? if you got edit go through it again. mark tuned my car it ran like ****. we picked up over .5 secods on our tune vs. his. do you have enough fule pump? good luck.
