C5 Nitrous problems
Old Mar 7, 2003 | 05:42 PM
NXC5man's Avatar
Default C5 Nitrous problems
I installed a NX wet system on my 99 C5 with a MSD rpm switch set to activate at 3200 and shut down at 6000. The kit works great on 75hp but if I take it to 100hp it will start missing around 5000 rpm. The computer will only let me run the car a couple of times then it throws a check engine light and goes into reduced power mode. I'm running NGK TR55 gapped at 36 thousands. I'm using the Jets that the kit called for. The only other mods I have to the car is Corsa cat back, Z06 carbon fiber air box, and thats it. I see alot of people on this web site running 100hp shots, what am I doing or not doing to make this happen? Any help would be great. Thanks <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Mar 7, 2003 | 06:31 PM
CAT3's Avatar
Restricted User
Default Re: C5 Nitrous problems
Not a troubleshooting pro, but I would recommend NGK TR6 plugs, more reliable for bigger shots-plus the whole fact you need a step colder plug per 100hp over stock issue. Good-luck.
Old Mar 7, 2003 | 06:55 PM
ANIL8U's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CAT3:
<strong> Not a troubleshooting pro, but I would recommend NGK TR6 plugs, more reliable for bigger shots-plus the whole fact you need a step colder plug per 100hp over stock issue. Good-luck. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You need the TR6's and you need to recheck the gap on the plugs(.32), Sounds like an easy fix.
Old Mar 20, 2003 | 11:50 AM
BayouVette's Avatar
Do you have pics of your install. I would really like to see. I think the is my next mod.
