Nitrous outlet halo system??
Old Feb 27, 2014 | 08:17 PM
dustind6327's Avatar
Default Nitrous outlet halo system??
I'm bout to order the halo system and curious I want to be on the safe side what else do I need to add to the kit to be on the safe side for the motor other than just spraying it and having fingers crossed
Old Feb 27, 2014 | 08:18 PM
And also how does it work with a six speed will it cut off during each shift?
Old Feb 27, 2014 | 08:49 PM
ragtopz28's Avatar
Window switch at a minimum....
Old Feb 27, 2014 | 08:55 PM
Rise of the Phoenix's Avatar
Yep, window switch would be a must. The NOS Mini controller has a built in window switch, WOT and TPS. Plus, it's a progressive controler with a handheld that you can make changes with on the fly.
Old Feb 28, 2014 | 09:11 AM
Is there a certain window swith I looked a found all kinds of them can u add a link so I could c
Old Feb 28, 2014 | 09:51 AM
brandon@nitrousoutlet's Avatar
http://www.nitrousoutlet.com/electro...ow-switch.html Here's a link to a good one.
Old Feb 28, 2014 | 10:06 AM
What about a fuel pressure safety switch? Would that be needed on a dry setup?
Old Feb 28, 2014 | 10:12 AM
I would recommend it. If fuel pressure drops the nitrous will shut off and lower the demand for fuel, potentially saving the motor.
