NOS fitting leak - what to use?
Old Mar 4, 2014 | 06:04 PM
brandonppr's Avatar
Default NOS fitting leak - what to use?
I've heard not to use teflon.
This is for the purge fitting.
The fitting is the small allen screw on the far left on this pic:
Old Mar 4, 2014 | 06:08 PM
1nverted's Avatar
Most of the vendors will tell you to use thread locker. i used thread locker on mine, no leaks.
Old Mar 4, 2014 | 08:26 PM
JDEP162's Avatar
agreed, instructions said teflon paste, worked on most fittings, the stubborn ones i was told thread locker, red loctite, sealed up fine.
Old Mar 4, 2014 | 08:37 PM
brandonppr's Avatar
Thanks
Old Mar 4, 2014 | 08:55 PM
boostit5.3's Avatar
red locktite and its never gonna come apart again lol... i use one pass of teflon tape starting halfway up the fitting and its always sealed perfect for me, its prolly a big no no but i've always used teflon and never had anything get clogged sloppy mech FTW! only thing is when changing fittings i always check the threads of the solenoid and scrape out any of the teflon tape that got left in there.
Old Mar 4, 2014 | 10:10 PM
Killer5.3's Avatar
I use blue loctite and never have a problem getting a fitting apart when I need to.
Old Mar 5, 2014 | 07:20 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Blue or red loctite works greats! You are correct on the teflon tape. Don't want to use that.
-Garrett
